Để tên bài như thế thật là khó tin phải không các bạn?! Nhưng đó là sự thật & mình chẳng nói xạo...nếu bạn không tin thì mời bạn vào user review trên gg play xem họ bình luận thế nào rồi download về cài trải nghiệm rồi hãy ném đá chủ topic nhé...
Sau đây trích 1 vài user review trên gg play: (https://play.google.com/store/apps/details?id=com.dianxinos.dxbs.paid&feature=search_result#?t=W251bGwsMSwxLDEsImNvbS5kaWFueGlub3MuZHhicy5wYWlkIl0.)
Donald Phillips - January 21, 2013 - Galaxy Precedent with version 2.1.0.proAs Avertised!!
Great App! Is it possible to report just what apps are doing when they launch themselfs univited?? Thanks
Spam
Olivia Williamson - February 21, 2013 - Samsung Galaxy S2 with version 2.1.0.pro
Brilliant
Extending my phone's battery life from an average of one and a half days to an average of 4 days, this app does exactly what it promises, quietly and perfectly.
Spam
David Cruz - February 3, 2013 - LG Optimus One with version 2.1.0.pro
Very Accurate
I downloaded last night,woke up this morning & my battery seems to not lose life as quickly keep up the good work for further future updates KingCruz
Spam
Cristian Kiss - February 25, 2013 - Version 2.1.0.pro
Error
1. Cant find to add this app to my white list. 2. Don't auto kill applications that run in background after 5 min. Samsung Galaxy Advanced
Spam
Ryan Gates - February 25, 2013 - Version 2.1.0.pro
Rooted Samsung Galaxy Note 2
Love the app, works great but the lower cpu isn't working.
Spam
Abdul Aziz - February 28, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Nice thing
Firstly I doubt on this product but after installing it I come to know that it is superb thing
Spam
Huy Truong - February 22, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Fantastic!
I've always loved this app. Quite sad when they removed from the market for a while. When I saw this again, I instantly jumped on it! Does what it says, well done.
Spam
Yessica Lima - January 30, 2013 - Version 2.1.0.pro
Great!!
It's very clean and easy to use, definitely recommend.
Spam
Jignesh Shah - February 19, 2013 - SEMC Xperia S with version 2.1.0.pro
Gives 10% improvement
Good app. Gives 10% improvement. Recommended for sure. I bought paid version.
Spam
A Google User - March 2, 2013 - Version 2.1.0.pro
Excellent
Excellent
Reden Christopher Godoy - February 24, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Great!
This application is my new best buddy!
Spam
chootipat ch. - February 6, 2013 - Version 2.1.0.pro
great apps
It can safe battery more than another app.
Spam
kyle gehrig - February 9, 2013 - Version 2.1.0.pro
Good product
Seems to work well on my note 2
Spam
Haitham Gendi - February 22, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Battery
Good Application. It is worth the money I paid.
Spam
Dat Nguyen - February 6, 2013 - Samsung Galaxy S3 with version 2.1.0.pro
Great
should get one for your phone
Spam
Andreas Budianto - January 18, 2013 - Version 2.1.0.pro
App
Good
Spam
Bret Barnes - February 26, 2013 - Version 2.1.0.pro
Battery Saver Du + Switch
This has made my battery last for ever. Worth the buy.
Spam
Kamari Denson - January 28, 2013 - HTC One X with version 2.1.0.pro
Good
Great app it really works wow
Spam
PRABHU S SONDESHH - January 29, 2013 - Version 2.1.0.pro
Working good.
Superb app
Spam
Fabian Baird - January 11, 2013 - Version 2.0.5.pro
Great app !! Must try !
3 days with it and it works awesome . With this real app you really save batery , super easy to use it too. Keep it up!!
Hầu hết đa số đều là review tốt...vậy tại sao không download về cùng cài trải nghiệm thử?
Quay lại app, mình xin giới thiệu vài tính năng chính:
★ Chẩn đoán pin một cách hết sức rõ ràng & thật là không thể tin được tiết kiệm pin.★ Chế độ chuyển đổi thông minh: ví dụ
- Điều chỉnh để chờ dài trên mức pin thấp;
- Đi vào chế độ cài đặt trước của bạn theo lịch trình của bạn;
★ Sạc kéo dài tuổi thọ pin. (ví dụ như gợi ý để sạc hoặc khi nào nên cắm sạc).
- Ra mắt Du Battery Saver để bắt đầu sạc khi pin thấp hơn 20%.
- It nhất 1 quá trình sạc đầy để kéo dài tuổi thọ pin.
★ Thường xuyên đóng những app chạy ngầm không cần thiết;
- Thiết lập khoảng thời gian các nhiệm vụ nền làm sạch;
- Cần để lại một số ứng dụng chạy nền? Thêm chúng vào danh sách bỏ qua.
★ Giảm xung CPU khi tắt màn hình (ROOT thiết bị);
=== Tính năng đã có ===
✔ 3 Widgets mạnh mẽ:
- One-tap tối ưu hóa (task-killer)
- Thiết kế pin hiển thị và chuyển đổi chế độ mới
- Công tắc mở tắt cao cấp
Đây là cách tiết kiệm pin dễ dàng bằng cách sử dụng tiện ích pin 1 tap, và kéo dài thời gian sử dụng hơn 15% bằng cách chuyển sang chế độ tiết kiệm pin, cũng đi với 1 tap widget mạnh mẽ.
✔ Tối ưu hóa sử dụng pin của bạn trong 3 chế độ cài đặt sẵn:
- Mode (chức năng cơ bản, đáp ứng nhu cầu tiết kiệm pin bình thường);
- Chế độ chờ (Đóng tất cả ngoại trừ quay số và SMS, kéo dài thời gian pin cho thời gian chờ dài nhất);
- Sleep Mode (Đóng tất cả trừ đồng hồ, tiết kiệm pin rất nhiều trong khi ngủ);
✔ Tùy chỉnh chế độ của bạn, thiết lập bất cứ điều gì bạn thích và tìm hiểu một trong những phù hợp nhất!
✔ Pin chỉ số, pin Cấp% trong thanh trạng thái sẽ chuyển sang màu đỏ khi <20%;
✔ Báo cáo dự kiến thời gian còn lại;
✔ Ringtone nhắc nhở cho tình trạng pin khác nhau;
✔ Chi tiết phân tích điện năng tiêu thụ, không chỉ các ứng dụng, mà còn là phần cứng (CPU, màn hình, cảm biến, WiFi, radio), pin theo dõi chuyên nghiệp nhất (pin thông báo) cho đến nay;
Hình ảnh về app:
Chi tiết:
Link Zippyshare / Kleii / Mega tốc độ cao:
Du Battery Saver+Switch Widget v3.4.0.pro apk (mới nhất trên gg play) Du Battery Saver+Switch Widget v3.3.0.pro apk
Cập nhật cho anh em:
JuiceDefender Ultimate v4.9.0 mới I+Cách dùng hiệu quả-App tiết kiệm pin "đỉnh" nhất hiện nay!Tổng hợp app tiết kiệm pin được dùng nhiều nhất trên gg play bản mới I link + cách sử dụng hiệu quả
More app & game trả phí cập nhật thường xuyên click here:
http://www.tinhte.vn/threads/1337665/http://www.tinhte.vn/threads/1319309/
Tổng hợp 57 Ứng dụng + 43 Games nên có trên Android + Topic tổng hợp đỉnh nhất trên tinh tế! | Viết bởi pretty.boy70
Để giúp anh em dễ cập nhật các phần mềm bên Topic phục vụ tìm ứng dụng và game cho anh em 24/24 (http://www.tinhte.vn/threads/1317401/), mình tạo ra trang tổng hợp này để thuận tiện cho anh em trong việc trải nghiệm những phần mềm pro....
